12-22-2016
07:30 AM
- Mute
- Permalink
- Report
12-22-2016
07:30 AM
Hi!
I'm trying to create two custom properties (Flat Pattern Extends: With and Length) in sheet metal parts within main assembly.
I tried another code, but it's only create the properties in the main assembly, not in the parts.
Now, I'm trying this code below, but it's not working yet.
Any help?
Thanks.
SyntaxEditor Code Snippet
Dim openDoc As Document openDoc = ThisApplication.activedocument Dim docFile As Document 'Is Assembly? If openDoc.DocumentType = 12291 Then For Each docFile In openDoc.AllReferencedDocuments 'Is Sheet Metal File? (assuming it has FP already) If docFile.SubType.Equals("{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}") Then 'if yes, Assuming it has a Flat Pattern deffined Dim smComp As SheetMetalComponentDefinition smComp = docFile.ComponentDefinition If smComp.HasFlatPattern = True Then 'CREATE With and Length as user properties (NOT WORKING) Dim Prop_Length As String Dim Prop_With As String oCustomPropertySet = ThisDoc.Document.PropertySets.Item _ ("Inventor User Defined Properties") oCustomPropertySet.Add("Custom", Prop_Length) oCustomPropertySet.Add("Custom", Prop_With) 'Adds Flat Pattern extends (Length and With) as a custom propertie (ready to use in a Part List Column) (NOT WORKING) docFile.oCustomPropertySet.Item("Design Tracking Properties").Item("Custom", "Length").Value = "=<Sheet Metal Length>" docFile.oCustomPropertySet.Item("Design Tracking Properties").Item("Custom", "Width").Value = "=<Sheet Metal Width>" 'THIS LINE IS TO ABLE THE Thickness PARAMETER TO GET READY TO EXPORT IN EACH SHEET METAL PART (WORKING) docFile.ComponentDefinition.Parameters("Thickness").ExposedAsProperty = True Else MessageBox.Show("No Flat Pattern Info ", "INFO!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) End If Else MessageBox.Show("Not a SM Part", "INFO!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) End If Next Else MessageBox.Show("This is not an Assembly", "File Type Mismatch!",MessageBoxButtons.OK,MessageBoxIcon.Exclamation) End If
CCarreiras
