SašoPrijatelj
The code you posted does nothing. It's only the beginning of the code. Did you make a mistake when copy-pasting or is that actual code you try to use?
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
