frederic.vandenplas
You can send extra information to a command (if you see it as a selectionset before activating a command)
This page explains alot about the commandmanager
http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
And you need something like this
Public Sub PlacePart()
    ' Get the command manager.
    Dim oCommandMgr As CommandManager
    Set oCommandMgr = ThisApplication.CommandManager
    ' Post the filename.
    Call oCommandMgr.PostPrivateEvent(kFileNameEvent, _
         "C:\Users\ekinsb\Documents\Inventor 2010\Showcasetest.ipt")
    ' Get control definition for the place component command.
    Dim oControlDef As ControlDefinition
    Set oControlDef = oCommandMgr.ControlDefinitions.Item( _
                                    "AssemblyPlaceComponentCmd")
    ' Execute the command.
    Call oControlDef.Execute
End Sub
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
