I'm afraid that doesn't resolve my particular issue. I'm trying to create an idw that automates the creation of a welded assembly and then 'draws' the assembly. When the geometry changes during this process, the caterpillar weld annotations need to be refreshed. I've managed to create weld symbols that disappear and reappear as needed (Thankfully, because as you've mentioned it is not exposed by the API).
I'm afraid that what I want to do is not exposed by the API either. As a last resort, I'm hoping to find a way to have iLogic select the 'Weld Annotations' checkbox and click 'OK' in the Drawing View form, similar to this browser node selection process for dealing with weld suppression: Run command on browser item
Here is an image of the caterpillar weld issue just in case I am not articulating it well enough:
