HermJan.Otterman
in reply to: Rob67ert
Hello Robert
you have to see iLogic as VB.net light.... and the api (application programmer interface) is the link between VB and Inventor.
there you can find all the things you can do with code in Inventor, that Autodesk lets you do.
Autodesk makes the API, and decide what is, and is not in the API.
when you look at the weld annotation, you can change only 2 or three objects, but there are many more that you can't program.
So the answer to you question is that with both iLogic and VB you can't fully program the weld symbol.
you can vote for this Idea:
 https://forums.autodesk.com/t5/inventor-ideas/weld-symbols-exposed-in-the-api-in-assemblies/idi-p/65...
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
