319 Views, 0 Replies
Hide nodes Browserfolder
Hi All ,
I have a question about browserfolders in inventor.
I have a code that hide the content (parts / component patterns) of a browserfolder and set bomstructure to reference in this folder .
But i want to specify it also for a Sub_Folder in this folder by giving the foldername as a argument.
1. when its a first level folder        : hide everything and set bomstructure in this folder (include the child subfolders)
2. When its a second  level folder : hide everything and set bomstructure ONLY in this folder
Below the code for case 1 (maby can be better) , cause a subfolder didn't hide
Private Sub SetFolderVisibility(ByVal FolderName As String, ByVal Visibility As Boolean)
On Error Resume Next
Dim oAssyDoc As Inventor.AssemblyDocument = ThisDoc.Document
oPane = ThisDoc.Document.BrowserPanes("Model")
'Get the browser folder object
oFolder = oPane.TopNode.BrowserFolders.Item(FolderName)
'Get the set of nodes in the folder
oFolderNodes = oFolder.BrowserNode.BrowserNodes
'Cycle through each browser node in the folder
	For Each oNode As BrowserNode In oFolderNodes
		oComp = oNode.NativeObject
		'set Visibility folder contents
	If Visibility = True Then
                oComp.BOMStructure = Inventor.BOMStructureEnum.kDefaultBOMStructure
                oComp.Visible = True
        Else
                oComp.BOMStructure = Inventor.BOMStructureEnum.kReferenceBOMStructure
                oComp.Visible = False
        End If
	Next
	Dim oOccurrencePattern As Inventor.OccurrencePattern = Nothing
	Dim OccurrencePatternName As String
	For Each oOccurrencePattern In oAssyDoc.ComponentDefinition.OccurrencePatterns
		Dim oOccurrencePatternElement As Inventor.OccurrencePatternElement
		For Each oOccurrencePatternElement In oOccurrencePattern.OccurrencePatternElements
			Dim oOcc As Inventor.ComponentOccurrence
			oOcc.Name = OccurrencePatternName
			For Each oOcc In oOccurrencePatternElement.Occurrences
				If oOcc.Visible = True Then
					oOcc.BOMStructure = Inventor.BOMStructureEnum.kDefaultBOMStructure
				Else If oOcc.Visible = False
					oOcc.BOMStructure = Inventor.BOMStructureEnum.kReferenceBOMStructure
				End If
			Next
		Next
	Next
End Sub
Thx for helping me
