- Mute
- Permalink
- Report
Export Part List Without Required Inventor to be Running
We are working on the export part list. Currently it is required Inventor to be running.
Is there any way to export a part list without Inventory running?
Thanks.
- Mute
- Permalink
- Report
Best you can do is to open inventor invisibly and export it from there.
The functionality is not exposed in Apprentice (as discussed here and a variety of other places on the forums: https://forums.autodesk.com/t5/inventor-customization/reading-parts-list-bom-via-apprentice-in-idw-f...)
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
Thanks for your reply.
1. Could you give some guidance for the code how to open inventor invisibly?
2. Is it possible to export full part list , including custom field without required Inventor running?
Thanks.
- Mute
- Permalink
- Report
around.
2. Definitely not.
- Mute
- Permalink
- Report
Hi ,
If we using open inventor invisibly , is it possible to export full part list with custom field as well?
Thanks.
- Mute
- Permalink
- Report
If we using open Inventor invisibly method , is it possible export full part list with custom field as well?
Thanks.
