371 Views, 1 Reply
10-25-2016
05:59 AM
- Mute
- Permalink
- Report
10-25-2016
05:59 AM
REvision Table Locating
I am having an issue with having the revision table and some of the other types of table we have on our title block to move with the border if the sheet size changes. Is there a code to write or a way to constrain the table to an existing point?
Any ideas will be helpful! Thanks! ![]()
10-27-2016
01:12 PM
- Mute
- Permalink
- Report
10-27-2016
01:12 PM
Hi --
The following rule will put the revision table into the upper-right corner of the active sheet. Is that enough to solve your problem? Let me know if you need more details. Note there are some assumptions (table name, use of X-coord, negative offset).
Also, I am not sure about the best way to trigger it. You can certainly run it manually.
SyntaxEditor Code Snippet
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim sht As Sheet = ActiveSheet.Sheet tableName = "Revision History" Dim revTab As RevisionTable = sht.RevisionTables.Item(tableName) Dim rbox As Box2D rbox = revTab.RangeBox tabWidth = rbox.maxPoint.x - rbox.minPoint.x Dim brdr As Border brdr = sht.Border Dim newPos as Point2d = brdr.rangebox.maxPoint.Copy Dim offset As Vector2d = oTG.CreateVector2D(-tabWidth, 0) newPos.TranslateBy(offset) revTab.position = newPos
Jon Balgley
