Hi Limin,
I used the same code in Inventor 2017 for removing the authoring for Cable and Harness and it seems to be working at my end.
Below is the code that I used to test at my end. This code is used to clear a value of a property that is set while authoring.
Sub RemoveAuthoringInfo()
 Dim oProperty As Property
 Set oProperty = ThisApplication.ActiveDocument.PropertySets.Item("32853F0F-3444-11d1-9E93-0060B03C1CA6").ItemByPropId(56)
 oProperty.Value = ""
End Sub
 If it is still not working at your end, could you let me know what version of Inventor you are using?
Sajith
Sajith Subramanian
Autodesk Developer Network
