in reply to:
06:54 AM
- Mute
- Permalink
- Report
10-18-2016
06:54 AM
So far I have this code which outputs all appearances found in a separate messagebox each (from parts in an assembly).
'Define the open document
Dim openDoc As Document
openDoc = ThisDoc.Document
'Create a dictionary which will be used to store the appearances
Dim Appearances As Object
Appearances = CreateObject("Scripting.Dictionary")
'Look at all of the files referenced in the open document
Dim docFile As Document
For Each docFile In openDoc.AllReferencedDocuments
'format file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
'Get the part faces
Dim oFaces As Faces
oFaces = docFile.ComponentDefinition.SurfaceBodies(1).Faces
'Loop through each face and store the appearance in the dictionary
Dim oFace As Face
For Each oFace In oFaces
Appearances(oFace.Appearance.DisplayName) = Appearances(oFace.Appearance.DisplayName)
Next
'Display the contents of the dictionary
For Each Item In Appearances
MessageBox.Show("Part: " & docFName & vbLf & "Appearance: " & Item)
Next
NextHowever, I am not sure how to make a form where I can input an appearance name and then format the dictionary so it displays only the parts which contains that appearance.
Any ideas?
