HermJan.Otterman
My files are created in 2016, You can't open them in 2015....
but here the are, open the assembly, delete part2. then insert part2 again, and they are connected.
here is a screencast: http://autode.sk/2dVrnIF
one other thing you could try is making the copy. this copy can be a dummy and should only have the iMate and Composite.
Place this dummy in the assembly (you will not see it, only in the browser). now you can use the replace function.
this is also less code and should work.
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
