HermJan.Otterman
I tried what you are doing in Inventor 2016 and it works fine...!?
I have a block1, cilinder1 and block 2.
block1 and cilinder1 are constrained.
block2 has one imate connecting with the other end of the cilinder1.
block2 has two imates in a composite connecting with block1
all imates/composite have matching names.
when I place block2 (manually), the imate and composite get connected
when I do this with your code, this also works.
it could be something with 2015?
what happens when you place it manually?
are the imates all at the same level in the browser? and not in a sub assembly?
what happens if you copy the part you want to place and create a different part (with other name).
then place one of the parts, so that the imate/composite are connected.
then Replace it with the copy. this should work. if not, then probably the imates are incorrect.
could you post a (stripped) assembly with the tree involving parts?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
