Jef_E
in reply to: ron.c
You should look under the drawingview object.
If can catch the correct drawingview you can set the active LOD
DrawingView.ActiveLevelOfDetailRepresentation Property
Parent Object: DrawingView
Description
Property that returns the name of the active Level of Detail Representation for a drawing view of an assembly. This property returns a null string for drawing views of parts and presentations and in the case where the model (assembly) is unresolved.
Syntax
DrawingView.ActiveLevelOfDetailRepresentation() As String
Version
Introduced in Inventor version 11
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
