wayne.brill
in reply to: demuff
I discussed your questions with a colleague and he suggested you shouldn’t need the rails because it will essentially be the same result with or without rails with the approach your taking. However I could try this to be sure.
It also looks like a major portion of each section is part of an arc.  It maybe be better to create two bodies, a cylinder and the complex shape at the top, and then cut the complex body from the cylinder to create the final shape.
If you upload something to test this with I will research it.
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
