- Mute
- Permalink
- Report
Hello Georg,
To get all the hole points from same type of holes to one sketch, you could try the following code which gets the hole centre points and adds them to a new sketch.
Dim xcoord As Double
Dim ycoord As Double
Dim oPt As Inventor.Point2d
' Create a new sketch on the XY plane.
Dim oNewSketch As PlanarSketch
Set oNewSketch = oCD.Sketches.Add(oCD.WorkPlanes.Item(3))
' Put the sketch in edit mode.
oNewSketch.Edit
For Each oHoleFeat In oDoc.ComponentDefinition.Features.HoleFeatures
If oHoleFeat.HoleType = HoleTypeEnum.kDrilledHole Then
xcoord = oHoleFeat.HoleCenterPoints.Item(1).Geometry.X
ycoord = oHoleFeat.HoleCenterPoints.Item(1).Geometry.Y
Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(xcoord, ycoord)
Call oNewSketch.SketchPoints.Add(oPt, True)
End If
Next
oNewSketch.ExitEdit
Sajith Subramanian
Autodesk Developer Network
