- Mute
- Permalink
- Report
Hi Georg,
In Inventor 2017, there is an api to create a pattern from a sketch.
Once you have your points moved to the sketch, you could use the sketch and the hole feature that needs to be patterned, to create a sketch based pattern.
In this case your code would be something similar to the following.
Sub addHole()
Dim oDoc As PartDocument
Set oDoc = ThisDocument
Dim oCD As PartComponentDefinition
Set oCD = oDoc.ComponentDefinition
Dim oHF As HoleFeature
Set oHF = oCD.Features.HoleFeatures.Item(1)
Dim oSK As PlanarSketch
Set oSK = oHF.Sketch
Call oSK.Edit
Dim oPt As Inventor.Point2d
Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(3 ,1 )
Call oSK.SketchPoints.Add(oPt, True)
Call oSK.ExitEdit
Dim oNewObjColl As ObjectCollection
Set oNewObjColl = ThisApplication.TransientObjects.CreateObjectCollection
Call oNewObjColl.Add(oSK.SketchPoints(1)) ' Existing hole centre
Call oNewObjColl.Add(oSK.SketchPoints(2)) ' New hole centre
oHF.HoleCenterPoints = oNewObjColl
'## Add the hole feature to an object collection
Dim oNewHolesColl As ObjectCollection
Set oNewHolesColl = ThisApplication.TransientObjects.CreateObjectCollection
Call oNewHolesColl.Add(oHF)
'## Pass the sketch and hole feature as input to create a pattern.
Dim defn As SketchDrivenPatternDefinition
Call oCD.Features.SketchDrivenPatternFeatures.Add(oCD.Features.SketchDrivenPatternFeatures.CreateDefinition(oNewHolesColl, oSK))
Sajith
Sajith Subramanian
Autodesk Developer Network
