MechMachineMan
This should get ya goin'.
Sub Main()
'Purpose: Push file name to sheet name
'21-Sept-16
Dim
oDoc As Document = ThisApplication.ActiveDocument Dim oSheet As Sheet Dim oDrawingView As DrawingView
'Iterate through sheets For Each oSheet In oDoc.Sheets
'Grab the first drawing view on the sheet oDrawingView = oSheet.DrawingViews(1)
'Grab the model of the first drawing view oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
'Assign the sheet name based off of the file name, with the path and extension removed oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName) Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
