- Mute
- Permalink
- Report
I currently have a drawing template that picks up the file of the part on that particular sheet. So i have "part A" on "sheet 1", the file name for "sheet 1" is "part a" - i then have "part b" on "sheet 2", therefore the file name for "sheet 2" is "part b."
Now with this in mind i need to modify this code (below) which automatically fills in the sheet name (eg sheet 1, sheet 2, sheet 3, etc) with the relevant part number. But i need to modify it so it picks up the active sheet file name. If i modify the code and put in the " iProperties.Value("Project", "Project") " it picks up the drawing file, and not the part on that drawing. Can someone help by making the code below pick up model information on the active sheet.
Sub Main If TypeOf ThisDoc.Document Is DrawingDocument Then Dim dwgDoc as DrawingDocument = ThisDoc.Document For Each dwgSheet As Sheet In dwgDoc.Sheets If dwgSheet.DrawingViews.Count > 0 Then modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument prtNumber = modelDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value If Not String.IsNullOrEmpty(prtNumber) Then dwgSheet.Name = prtNumber End If End If Next End If End Sub
The information i need to have automatically filled is the code below, but it must be looking at the active sheet file name and not the documemnt file name. Hopefully i've made sense
SyntaxEditor Code Snippet
SyntaxEditor Code SnippetSub Main If TypeOf ThisDoc.Document Is DrawingDocument Then Dim dwgDoc as DrawingDocument = ThisDoc.Document For Each dwgSheet As Sheet In dwgDoc.Sheets If dwgSheet.DrawingViews.Count > 0 Then modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument prtNumber = modelDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value If Not String.IsNullOrEmpty(ThisDoc.FileName) Then dwgSheet.Name = ThisDoc.FileName End If End If Next End If End Sub
