- Mute
- Permalink
- Report
I currently have a drawing template that picks up the file of the part on that particular sheet. So i have "part A" on "sheet 1", the file name for "sheet 1" is "part a" - i then have "part b" on "sheet 2", therefore the file name for "sheet 2" is "part b."
Now with this in mind i need to modify this code (below) which automatically fills in the sheet name (eg sheet 1, sheet 2, sheet 3, etc) with the relevant part number. But i need to modify it so it picks up the active sheet file name. If i modify the code and put in the " iProperties.Value("Project", "Project") " it picks up the drawing file, and not the part on that drawing. Can someone help by making the code below pick up model information on the active sheet.
Sub Main If TypeOf ThisDoc.Document Is DrawingDocument Then Dim dwgDoc as DrawingDocument = ThisDoc.Document For Each dwgSheet As Sheet In dwgDoc.Sheets If dwgSheet.DrawingViews.Count > 0 Then modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument prtNumber = modelDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value If Not String.IsNullOrEmpty(prtNumber) Then dwgSheet.Name = prtNumber End If End If Next End If End Sub
The information i need to have automatically filled is the code below, but it must be looking at the active sheet file name and not the documemnt file name. Hopefully i've made sense
SyntaxEditor Code Snippet
SyntaxEditor Code SnippetSub Main If TypeOf ThisDoc.Document Is DrawingDocument Then Dim dwgDoc as DrawingDocument = ThisDoc.Document For Each dwgSheet As Sheet In dwgDoc.Sheets If dwgSheet.DrawingViews.Count > 0 Then modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument prtNumber = modelDoc.PropertySets("{32853F0F-3444-11D1-9E93-0060B03C1CA6}").ItemByPropId(5).Value If Not String.IsNullOrEmpty(ThisDoc.FileName) Then dwgSheet.Name = ThisDoc.FileName End If End If Next End If End Sub
- Mute
- Permalink
- Report
i am no expert on code i did find this in a similar post maybe it will work for you:
Dim oSheets As Sheets = ThisDrawing.Document.sheets Dim oSheet As Sheet For Each oSheet In oSheets oSheet.activate Dim oDrawingView As DrawingView = oSheet.DrawingViews(1) oModel = ActiveSheet.View(oDrawingView.Name).ModelDocument PartNumb = iProperties.Value(oModel.DisplayName, "Project", "Part Number") ActiveSheet.Sheet.Name = PartNumb Next
- Mute
- Permalink
- Report
Ignore this... was typos and bugged posting...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
- Mute
- Permalink
- Report
This should get ya goin'.
Sub Main()
'Purpose: Push file name to sheet name
'21-Sept-16
Dim oDoc As Document = ThisApplication.ActiveDocument Dim oSheet As Sheet Dim oDrawingView As DrawingView
'Iterate through sheets For Each oSheet In oDoc.Sheets
'Grab the first drawing view on the sheet oDrawingView = oSheet.DrawingViews(1)
'Grab the model of the first drawing view oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
'Assign the sheet name based off of the file name, with the path and extension removed oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName) Next
End Sub
- Mute
- Permalink
- Report
Hello, I am trying to Copy/Paste this rule into my Drawing and it errors out when I try to Save/Run. We are basically looking to do this exact same thing I believe. After I detail an ipt I want the name on the tree to match the name in the title block. The title block is pulling the FILENAME from the Model Parameters, but I can't figure out how to make the tree name it the same. Thanks in advance!
- Mute
- Permalink
- Report
The only error I could bring up is when no model was present in one of the sheets. As this rule loops through all sheets and looks for view (1) if missing it will error out. Included in the rule below is an error trap for skipping the sheet renaming when no view is present. If this still doesn't work can you post the error message that you have received?
Sub Main() 'Purpose: Push file name to sheet name '21-Sept-16 Dim oDoc As Document = ThisApplication.ActiveDocument Dim oSheet As Sheet Dim oDrawingView As DrawingView 'Iterate through sheets For Each oSheet In oDoc.Sheets Try 'Grab the first drawing view on the sheet oDrawingView = oSheet.DrawingViews(1) 'Grab the model of the first drawing view oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument 'Assign the sheet name based off of the file name, with the path and extension removed oSheet.Name = System.IO.Path.GetFileNameWithoutExtension(oModel.FullFileName) Catch 'Error no view so skip End Try Next End Sub
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
You have to have a model file or iam file on the sheet, otherwise it will error
- Mute
- Permalink
- Report
That did it! Thanks so much! This stuff is a bit confusing. We are going to look into a training program for the coding side of inventor as we seem to run into a lot of issues lately.
