09-21-2016
05:34 AM
- Mute
- Permalink
- Report
09-21-2016
05:34 AM
Hi PhilLindsay4781,
So just to clarify: you first created 2 parts list styles and ensured that the code matched the names of those styles, and in those styles you have the columns set up as needed?
If that is correct, then this code should work. It works by checking for an existing parts list, and placing one if not. Then it sets the style for the parts list.
@Anonymous wrote:
Can iLOGIC edit the column designation or am I trying to do something that isn't possible?
It might be possible, but it would basically be creating a style override for your parts list, which would make updating drawings later a bit more difficult. So I don't think it would not be the recommended method due to that.
I hope this helps.
Curtis
