- Mute
- Permalink
- Report
Recognize holes
Hello together,
sometimes I use the add-in feature recognition.
https://apps.autodesk.com/PDSU/en/Detail/Index?id=9172877436288348979&appLang=en&os=Win32_64
The feature recognition recognize each hole as a separate hole. Is it possible to find all holes from the same type and replace them with a pattern?
How could I get the positions of the holes? Or is it possible to move all holes of the same type to one sketch?
Thanks Georg
- Mute
- Permalink
- Report
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oHoleFeat As HoleFeature
For Each oHoleFeat In oDoc.ComponentDefinition.Features.HoleFeatures
Debug.Print ("X:" & oHoleFeat.HoleCenterPoints.Item(1).X)
Debug.Print ("Y:" & oHoleFeat.HoleCenterPoints.Item(1).Y)
Debug.Print ("Z:" & oHoleFeat.HoleCenterPoints.Item(1).Z)
Debug.Print ("Durchmesser:" & oHoleFeat.HoleDiameter.Expression)
Debug.Print ("Bohrungstiefe:" & oHoleFeat.Extent.Distance.Expression)
Next
Sub addHole()
Set oDoc = ThisDocument
Dim oCD As PartComponentDefinition
Set oCD = oDoc.ComponentDefinition
Dim oHF As HoleFeature
Set oHF = oCD.Features.HoleFeatures.Item(1)
Dim oSK As PlanarSketch
Set oSK = oHF.Sketch
Call oSK.Edit
Dim oPt As Inventor.Point2d
Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(3, 1)
Call oSK.SketchPoints.Add(oPt, True)
Call oSK.ExitEdit
Dim oNewObjColl As ObjectCollection
Set oNewObjColl = ThisApplication.TransientObjects.CreateObjectCollection
Call oNewObjColl.Add(oCD.Sketches(2).SketchPoints(1)) ' Existing hole centre
Call oNewObjColl.Add(oCD.Sketches(2).SketchPoints(2)) ' New hole centre
oHF.HoleCenterPoints = oNewObjColl
End Sub
- Mute
- Permalink
- Report
Hi Georg,
I understand the hole is sketch based. Hence, you would need to access the X, Y, Z coordinates using the Geometry API in the for loop
So instead of
you could use
Debug.Print ("X:" & oHoleFeat.HoleCenterPoints.Item(2).Geometry.X)
Also, in the addHole() subroutine you could change
to use the reference sketch of the hole.
Call oNewObjColl.Add(oSK.SketchPoints(1))
Please let me know if this helps.
Sajith
Sajith Subramanian
Autodesk Developer Network
- Mute
- Permalink
- Report
Hello Sajith,
the first problem is to get the position of each hole. The second problem is to compare the different holes and move them to the right sketch.
Could you help me with the comparison of the holes?
Georg
- Mute
- Permalink
- Report
Hi Georg,
To compare the type of holes you could use the Holetype api.
A simple way would be to filter out the type in the for loop itself.
If oHoleFeat.HoleType = HoleTypeEnum.kDrilledHole Then 'Filter out the drilled holes
End if
Next
Similarly you can filter out the various types by referring below.
kCounterBoreHole | : | Hole is counterbored. |
kCounterSinkHole : | Hole is countersunk. | |
kDrilledHole : | Hole is drilled (no countersink or counterboring). | |
kSpotFaceHole : | Hole is spotfaced. |
Sajith
Sajith Subramanian
- Mute
- Permalink
- Report
Hello Sajith,
thanks for the sample code. But how could I recognize if the holes could be patternd?
Georg
- Mute
- Permalink
- Report
Hi Georg,
In Inventor 2017, there is an api to create a pattern from a sketch.
Once you have your points moved to the sketch, you could use the sketch and the hole feature that needs to be patterned, to create a sketch based pattern.
In this case your code would be something similar to the following.
Sub addHole()
Call oSK.Edit
Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(3 ,1 )
Call oSK.ExitEdit
Call oNewObjColl.Add(oSK.SketchPoints(1)) ' Existing hole centre
Call oNewObjColl.Add(oSK.SketchPoints(2)) ' New hole centre
'## Add the hole feature to an object collection
Dim oNewHolesColl As ObjectCollection
Set oNewHolesColl = ThisApplication.TransientObjects.CreateObjectCollection
Call oNewHolesColl.Add(oHF)
'## Pass the sketch and hole feature as input to create a pattern.
Dim defn As SketchDrivenPatternDefinition
Call oCD.Features.SketchDrivenPatternFeatures.Add(oCD.Features.SketchDrivenPatternFeatures.CreateDefinition(oNewHolesColl, oSK))
Sajith
Sajith Subramanian
- Mute
- Permalink
- Report
Hello Sajith,
I am searching for an easy way to get all points from the same holes to one sketch. Do you know a way to do this?
Georg
- Mute
- Permalink
- Report
Hello Georg,
To get all the hole points from same type of holes to one sketch, you could try the following code which gets the hole centre points and adds them to a new sketch.
Dim xcoord As Double
Dim ycoord As Double
' Create a new sketch on the XY plane.
Dim oNewSketch As PlanarSketch
Set oNewSketch = oCD.Sketches.Add(oCD.WorkPlanes.Item(3))
' Put the sketch in edit mode.
oNewSketch.Edit
xcoord = oHoleFeat.HoleCenterPoints.Item(1).Geometry.X
ycoord = oHoleFeat.HoleCenterPoints.Item(1).Geometry.Y
Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(xcoord, ycoord)
Call oNewSketch.SketchPoints.Add(oPt, True)
End If
Next
oNewSketch.ExitEdit
Sajith Subramanian
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Hello Sajith,
with this code the orientation of the holes changes if the holes are not on the XY-plane:
How could I keep it?
Georg
- Mute
- Permalink
- Report
Hello Sajith,
how could I replace a hole with another hole-feature (save the position, delete the hole and replace it with another one)?
Georg
- Mute
- Permalink
- Report
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button65.Click
Dim m_inventorApp As Inventor.Application = Nothing
' Try to get an active instance of Inventor
Try
m_inventorApp = System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application")
Catch ex As Exception
MsgBox(ex.Message)
End Try
' Create a transaction.
Dim oTransMgr As TransactionManager
oTransMgr = m_inventorApp.TransactionManager
Dim oTrans As Transaction
oTrans = oTransMgr.StartTransaction(m_inventorApp.ActiveDocument, "Replace hole")
Dim oSketch As PlanarSketch = Nothing
oDoc = m_inventorApp.ActiveDocument
' Set a reference to the component definition.
Dim oCompDef As PartComponentDefinition
oCompDef = oDoc.ComponentDefinition
Dim oHoles As HoleFeatures
oHoles = oDoc.ComponentDefinition.Features.HoleFeatures
Dim oHole As HoleFeature
For Each oHole In oHoles
oDoc.SelectSet.Clear()
oDoc.SelectSet.Select(oHole)
Dim oHoleCenter As Point
Dim oSketchPoint As SketchPoint
Dim oCollection As ObjectCollection
oCollection = m_inventorApp.TransientObjects.CreateObjectCollection
If TypeOf oHole.HoleCenterPoints.Item(1) Is SketchPoint Then
' Get the sketch point.
oSketchPoint = oHole.HoleCenterPoints.Item(1)
' Get the position of the sketch point in model space.
oSketch = oSketchPoint.Parent
oHoleCenter = oSketch.SketchToModelSpace(oSketchPoint.Geometry)
'Dim oSketchpoint As SketchPoint
For Each oSketchPoint In oHole.Sketch.SketchPoints
If oSketchPoint.HoleCenter Then
Call oCollection.Add(oSketchPoint)
End If
Next
'Löschen
oHole.Delete(True)
Call oCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent(oCollection, "10 mm", PartFeatureExtentDirectionEnum.kPositiveExtentDirection)
oDoc.Update()
Else
oHoleCenter = oHole.HoleCenterPoints.Item(1)
MsgBox(oHoleCenter.X & "; " & oHoleCenter.Y & "; " & oHoleCenter.Z)
' How to replace the hole without sketch?
End If
Next
oTrans.End()
End SubHow could I replace the holes without sketch?
- Mute
- Permalink
- Report
Hi George,
Please find the sample code to change the hole without sketch
Public Sub ModifY_Hole()
Try
MsgBox(ex.Message)
End Try
Dim ohole As HoleFeature
ohole = m_inventorApp.CommandManager.Pick(SelectionFilterEnum.kPartFeatureFilter, "Select hole feature")
ohole.SetCBore("10 mm", "2.5 mm")
oTrans.End()
End Sub
Please feel free to contact if there is any doubt.
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
Hello Chandra,
thank you very much for the code. But the holes could not be changed in all cases. There is another post with the same problem:
I think there is a bug in the API because I can reproduce the errors.
Georg
- Mute
- Permalink
- Report
Hi George,
My example works for PartDocument. Meanwhile, it is very switch to AssemblyDocument. I gone through the link provided in the post. There is no such example is explained.
Can you please provide example with situation? I will look into it.
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
Hello Chandra,
the first idea was to copy the hole settings from one hole to another one. But this does not work very stable at all. Therefore I tried to get the position of the origin hole, delete it, and put a new one at the origin position. But this does not work either very stable.
https://forums.autodesk.com/autodesk/attachments/autodesk/120/70598/1/Platte_Bohrungen00_2017.ipt
Maybe you could find a stable solution that works in part and assembly environment.
Your code works for some holes, but not for all. For one hole it works and for the next one it does not work. The type of holes are equal.
Thank you
Georg
- Mute
- Permalink
- Report
Hi George,
There are few holes which is having "LinearHolePlacementDefinition" fails to convert other hole types. Which throws an exception "The parameter is incorrect". It may be due to references of "LinearHolePlacemntDefinition" as shown in the following image. Other than, many hole types are able to convert hole types.
CHANDRA SHEKAR G
Developer Advocate
- Mute
- Permalink
- Report
Hello Chandra,
Wayne Brill did some modifications to solve the problem. But the code does not work for all hole types and directions.
Thank you Georg
- Mute
- Permalink
- Report
Hi George,
Please see go through the following sample code. It adds a drilled hole feature using "LinearHolePlacementDefinition"
Dim oLinearPlacementDef As LinearHolePlacementDefinition
Set oLinearPlacementDef = oCompDef.Features.HoleFeatures.CreateLinearPlacementDefinition _
(oFace, oEdge1, "2 cm", oEdge2, "2 cm", oBiasPoint)
' Create the hole feature.
Call oCompDef.Features.HoleFeatures.AddDrilledByThroughAllExtent( _
oLinearPlacementDef, "1 cm", kPositiveExtentDirection)
For definition of "LinearHolePlacementDefinition" requires more parameters like face, edges and base point. So, unable to convert these kind of holefeature.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
