1138 Views, 3 Replies
09-07-2016
10:55 AM
- Mute
- Permalink
- Report
09-07-2016
10:55 AM
Using the PDF Translator with Inventor 2016 API
I am trying to write a VBA function that saves PDF files automatically. I have been using Document.SaveAs(), however I need to be able to control the sheet range that is exported. My function is as follows:
Public Sub SaveAsPDF(ByVal doc As Document)
Dim oPDFAddIn As TranslatorAddIn
oPDFAddIn = _invApp.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
Dim oContext As TranslationContext
oContext = _invApp.TransientObjects.CreateTranslationContext
oContext.Type = kFileBrowseIOMechanism
Dim oOptions As NameValueMap
oOptions = _invApp.TransientObjects.CreateNameValueMap
Dim oDataMedium As DataMedium
oDataMedium = _invApp.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
End If
'Set the PDF target file name
oDataMedium.FileName = "C:\test.pdf"
'Publish document
oPDFAddIn.SaveCopyAs(doc, oContext, oOptions, oDataMedium)
End SubWhen I run the function, passing it the open document (which is a drawing) I get a message in Inventor that says "Failed to publish DWF file" and when I click cancel I get the following error in my MSVS debugger on the oPDFAddIn.SaveCopyAs(doc, oContext, oOptions, oDataMedium) line:
I verified that {0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4} is the PDF translator ID, and even tried {0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}, which is the DWF translator.
Any guidance would be much appreciated!
Rohan Jhunjhunwala
