Christian_1976
834 Views, 2 Replies
c# insert ipt in assembly - user interaction
Good morning everyone,
i'm rewriting in c# some of my very old tools written years ago in vba.
(Doing that using Inventor 2017 and visual studio 2015 )
I'm going quite well with the rewriting but i'm locked with inserting an ipt into an assembly giving to the user the opportunity to choose the displacing point.
(I can add component by adding it to the assembly document ComponentOccurrences, but no user interaction)
In Vba, the way that i used was calling Command manager like this:
Call ThisApplication.CommandManager.PostPrivateEvent(kFileNameEvent, sFile)
Call ThisApplication.CommandManager.StartCommand(kPlaceComponentCommand)
now i'm doing this:
m_InventorApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, sFile);
I can't find in CommandManager something that can replace the StartCommand.
I see in the api doc that there is a CreateDragContext as CommandManager method
I want to ask if:
-anybody knows if however is the right way to give to the user the control of where to place the new component in the assembly
-anybody knows how to do that in c#
thank you in advance
Christian
ekinsb
in reply to: Christian_1976
What you've run into isn't a change from VBA to C# but is a change that was made in the API quite a while ago.  The StartCommand method has been retired.  You can still accomplish the same thing by first getting the CommandDefinition that represents the command and then executing it.  Below os some sample code that demonstrates what you're trying to do.
string filename = "C:/Temp/Tests/EllipsePart.ipt";
// Post the filename to the private event queue.
invApp.CommandManager.PostPrivateEvent(Inventor.PrivateEventTypeEnum.kFileNameEvent, filename);
// Get the control definition for the Place Component command.
Inventor.ControlDefinition ctrlDef = invApp.CommandManager.ControlDefinitions["AssemblyPlaceComponentCmd"];
// Execute the command.
ctrlDef.Execute();
Brian Ekins
Mod the Machine blog
Christian_1976
in reply to: ekinsb
I'm deeply sorry to answer you only now, after a so long time, but i had to stop suddenly my task and i'm now review it all.
Your solution works, thank you a lot.
:slightly_smiling_face:
