in reply to:
08:40 AM
- Mute
- Permalink
- Report
09-02-2016
08:40 AM
That helped? Thanks! Here is the final code in case others have a similar issue.
Public Sub SetParameterFormatToSixteenthsFractional()
'Get the active assembly document.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
'Iterate through all of the documents referenced by the assembly.
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
'Check to see if this is a part.
If oDoc.DocumentType = kPartDocumentObject Then
Debug.Print oDoc.FullFileName
Dim oPartDoc As PartDocument
Set oPartDoc = oDoc
Dim oUserParams As UserParameters
Set oUserParams = oPartDoc.ComponentDefinition.Parameters.UserParameters
'Check to see if the part document contains user parameters.
If oUserParams.Count > 0 Then
Dim oUserParam As UserParameter
'Loop through each user paramter.
For Each oUserParam In oUserParams
'look for user parameter G_L.
If oUserParam.Name = "G_L" Then
Debug.Print oUserParam.Name
Set oUserParam = oUserParams.Item("G_L")
oUserParam.CustomPropertyFormat.Precision = kSixteenthsFractionalLengthPrecision
End If
Next oUserParam
End If
End If
Next oDoc
End Sub
