The code below should get you pointed in the right direction. It just adds multi-value Parameters and changing User Parameter. I hope this helps in some way.
SyntaxEditor Code Snippet
Imports  Inventor.UnitsTypeEnum
Dim oAssemblyDoc As Document
oAssemblyDoc = ThisDoc.Document
If oAssemblyDoc.DocumentType = kAssemblyDocumentObject Then
    Dim oAssemblyCompDef As AssemblyComponentDefinition
        oAssemblyCompDef = oAssemblyDoc.ComponentDefinition
Dim oParams As Parameters
        oParams=oAssemblyCompDef.Parameters
        Dim oUserParams As UserParameters
        oUserParams=oParams.UserParameters
        Dim oAwesomeParameter As Parameter
                    Try
            otester = oUserParams.Item("PK_Extended_Item_Description")
            Catch
oInsulationType=oUserParams.AddByValue("PK_Extended_Item_Description", "General", kTextUnits)
MultiValue.SetList("PK_Extended_Item_Description", "Manufacturing", "Purchasing", "General", "Customer Order", "Phantom")
            End Try
            End If
Parameter.Param("PK_Extended_Item_Description").ExposedAsProperty = False
Parameter.Param("PK_Extended_Item_Description").IsKey = False
