3575 Views, 8 Replies
Change User Parameter Custom Property with VBA
Inventor 2017
All updates and hot fixes installed
When I create an assembly that has a frame (constructed with Frame Gen) in it i have to go in to each individual part file and change the G_L user parameter "Custom property format" from "Decimal" to "Fractional" and change the "Precision" to "1/16th". I would like to do this through VBA (or iLogic if possible).  The code i wrote shows the error in the attached pic when i try to run it.  Can anyone help??  I have attached a pic of my code as well because when i paste it on here its hard to read.
Public Sub ChangeParameterFormat()
' Get the active assembly document.
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
' Iterate through all of the documents referenced by the assembly.
Dim oDoc As Document
For Each oDoc In oAsmDoc.AllReferencedDocuments
' Check to see if this is a part.
If oDoc.DocumentType = kPartDocumentObject Then
Dim oPartDoc As PartDocument
Set oPartDoc = oDoc
Dim oUserParams As UserParameters
Set oUserParams = oPartDoc.ComponentDefinition.Parameters.UserParameters
Dim i As Integer
For i = 0 To oUserParams.Count
oUserParams.Item(i).CustomPropertyFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kSixteenthsFractionalLengthPrecision
Next i
End If
Next
End Sub
