08-31-2016
06:52 AM
- Mute
- Permalink
- Report
08-31-2016
06:52 AM
That seems to find the external rule whether or not the part in the drawing is using it or not. So that will not work for what I'm doing.
I need to explicitly check if the part inside a drawing has an active external rule, not if an external rule exists.
The only method I know will work would be to have a one line internal rule that calls an external rule. That way I can use some code that lists internal rules in a component to see if it exists in a part. The reason I'm reluctant to do that is all the parts created with the external rule already won't be updated properly.
