MegaJerk
in reply to: pball
As described here, depending on when a given file was created (or at least which version of Inventor it was created with) the PropertySet for Event Triggers might be hidden.
Instead of using the PropertySet name "iLogicEventsRules" or "_iLogicEventsRules", search for the GUID "{2C540830-0723-455E-A8E2-891722EB4C3E}"
I hope that this gets you started in the right direction.
If my solution worked or helped you out, please don't forget to hit the kudos button :slightly_smiling_face:
iLogicCode Injector: goo.gl/uTT1IB
GitHub
