frederic.vandenplas
in reply to: pball
Maybe not a neat solution but If you try to run the external rule, an error will occur, if you capture the error, you can proceed with
the rest of your code.
Try
iLogicVb.RunExternalRule("c:\test.vb")
Catch
MsgBox("The external rule cannot be found")
End Try
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
