jmfowler1996
Hi there.
This is how to open a form on the creation of a new document:
1. Create a new rule ( call it something like 'Open Form' ).
2. Paste this code into the rule and accept:
iLogicForm.Show("My Form")
   -Obviously substitute "My Form" with the name of your form.
3. Navigate to Ribbon -> Manage -> iLogic -> Event Triggers -> New Document.
4. Select "New Document" and click "Select Rules...".
5. Here, just toggle on your new rule ("Open Form") and accept.
This is how to use the iTrigger as a button to open your form:
1. Create a new rule ( call it something like 'Open Form' ). -or use the existing one if you have it.
trigger = iTrigger0
3. Navigate to Ribbon -> Manage -> iLogic -> iTrigger
4. Right-click on iTrigger and select "Add to Quick Access Toolbar".
5. Now just click on the little iTrigger symbol whenever you want to open the form.
How to add a marking menu (right-click and drag) shortcut to open your form:
1. Create an iTrigger shortcut as above.
2. Navigate to Ribbon -> Tools -> Options -> Customize -> Marking Menu.
3. Choose the sub-environment you want to use for the shortcut. I use a 'Ctrl + Right-Click' sub, but you will probably want "None Selected".
4. Choose a button to become your shortcut. Click it and then use the search box to find "iTrigger". Click it from the list and apply your changes.
I hope this solves your problem. I would be happy to help if something goes wrong.
Good luck.
Jonathan
