Curtis_Waguespack
Hi aliceloneragan,
 I use this to copy event triggers from my templates. I set up external rules with event triggers in the templates, and then I have this "Copy Event Triggers rule" called from various other external rules as needed. I almost never use internal rules.
Keep in mind, I repurposed a rule I found on line, and so there is likely some extra stuff in there that is not needed, etc. I never did go back through it and clean it up.
Here is a batch processor also:
http://forums.autodesk.com/t5/inventor-general-discussion/any-way-to-automatically-update-all-relate...
I hope this helps.
Curtis
Imports System.Collections.Generic
'code taken and modified from:
'http://adndevblog.typepad.com/manufacturing/2015/01/add-external-ilogic-rule-to-event-trigger.html
Sub Main
Trace.WriteLine("Event Driven Rules Copy", "iLogic") 'debug
	Dim oTemplateDoc As Document
	Dim oTemplate As String
	'check file type
	If ThisApplication.ActiveEditDocument.DocumentType = kDrawingDocumentObject Then
	'If ThisDoc.Document.DocumentType = kDrawingDocumentObject Then
		oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.idw"   'file to copy events from
	ElseIf ThisApplication.ActiveEditDocument.DocumentType = kPartDocumentObject Then
	'ElseIf ThisDoc.Document.DocumentType = kPartDocumentObject Then
		oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.ipt"   'file to copy events from
	Else
		oTemplate = "\\server\departments\CAD\Inventor\Templates\Standard.iam"   'file to copy events from
	End If
	'file to copy events to
	oInput =  ThisApplication.ActiveEditDocument.FullFileName
	If oInput = "" Then 'catch a new file with no path
		Return
	End If
	'open the template
	oTemplateDoc = ThisApplication.Documents.Open(oTemplate, False)
	CopyEventsToDocuments(oTemplateDoc)
	oTemplateDoc.Close
End Sub
Private Const m_ourGuid As String = "{2C540830-0723-455E-A8E2-891722EB4C3E}"
Private savedEnabled As Boolean
Dim oInput As String
Public Sub CopyEventsToDocuments(ByVal sourceDoc As Document)
	Dim sourcePropSet As PropertySet = GetEventRulesPropertySet(sourceDoc)
	Dim inputs() As String = { oInput}
	Dim destinationFileNames As List(Of String) = New List(Of String)(inputs)
	If (destinationFileNames Is Nothing) Then Return
	savedEnabled = iLogicVb.Automation.RulesOnEventsEnabled
	iLogicVb.Automation.RulesOnEventsEnabled = False
	Try
		CopyEventsToAllDocuments(sourcePropSet, sourceDoc, destinationFileNames)
	Finally
		iLogicVb.Automation.RulesOnEventsEnabled = savedEnabled
	End Try
End Sub
Function GetEventRulesPropertySet(ByVal sourceDoc As Document) As PropertySet
	Try
		Return sourceDoc.PropertySets(m_ourGuid)
	Catch ex As Exception
		Return Nothing
	End Try
End Function
Function VerifyRulesPropertySet(ByVal propSet As PropertySet) As Boolean
	If (propSet Is Nothing) Then Return True
	' See if any rules are internal instead of external.  We can't copy those.
	For Each prop As Inventor.Property In propSet
		Dim strValue As String = prop.Value.ToString
		If (Not strValue.StartsWith("file://")) Then Return False
	Next
	Return True
End Function
Sub CopyEventsToAllDocuments(ByVal sourcePropSet As PropertySet, ByVal sourceDoc As Document, ByVal destinationFileNames As List(Of String))
	For Each fileName As String In destinationFileNames
		If (String.Equals(sourceDoc.FullFileName, fileName)) Then Continue For
		CopyEventsToDocument(sourcePropSet, fileName)
	Next
End Sub
Sub CopyEventsToDocument(ByVal sourcePropSet As PropertySet, ByVal fileName As String)
	'Dim doc As Document = FindOpenDocument(fileName)
	Dim openedHere As Boolean = False
	If (doc Is Nothing) Then
		doc = ThisApplication.Documents.Open(fileName, True)
		openedHere = True
	End If
	CopyEventsPropertySetToDocument(sourcePropSet, doc)
End Sub
Sub CopyEventsPropertySetToDocument(ByVal sourcePropSet As PropertySet, ByVal doc As Document)
	' If an event-driven rules property set already exists, delete it.
	Dim oldPropSet As PropertySet = GetEventRulesPropertySet(doc)
	If (oldPropSet IsNot Nothing) Then
		oldPropSet.Delete()
	End If
	If (sourcePropSet Is Nothing OrElse sourcePropSet.Count = 0) Then Return
	Dim destPropSet As PropertySet = doc.PropertySets.Add("_iLogicEventsRules", m_ourGuid)
	For Each prop As Inventor.Property In sourcePropSet
		destPropSet.Add(prop.Value, prop.Name, prop.PropId)
	Next
	EnsureDocumentInterest(doc)
End Sub
Const iLogicId As String = "{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}"
Sub EnsureDocumentInterest(ByVal doc As Document)
	If (ThisApplication.SoftwareVersion.Major < 15) Then Return ' Inventor 2010 or before
	If (DocumentHasiLogicInterest(doc)) Then Return
	Dim dataVersion As Integer = 20090512
	Dim newInterest As DocumentInterest = doc.DocumentInterests.Add(iLogicId, "iLogic", DocumentInterestTypeEnum.kInterested, dataVersion, Nothing)
End Sub
Function DocumentHasiLogicInterest(ByVal doc As Document) As Boolean
	Dim interest As DocumentInterest = FindDocumentInterest(doc, iLogicId)
	If (interest IsNot Nothing) Then
		If (interest.InterestType = DocumentInterestTypeEnum.kInterested) Then
			Return True
		End If
		interest.Delete()
	End If
	Return False
End Function
Function FindDocumentInterest(ByVal doc As Document, ByVal clientId As String) As DocumentInterest
	For Each interest As DocumentInterest In doc.DocumentInterests
		If (String.Equals(interest.ClientId, clientId, StringComparison.OrdinalIgnoreCase)) Then
			Return interest
		End If
	Next
	Return Nothing
End Function
