- Mute
- Permalink
- Report
I thought this one would be easy but is causing me some trouble. I have several BOM configurations that I need to export out of inventor. Right now I import the xml. file to get the configuration I want then check it before exporting the file. Is there a way to import the xml. file using iLogic?
My plan is to have the different BOM configurations set up as external rules and using a global form I can click on whatever BOM configurations I need to use. This way I just open the BOM and it’s ready to view or export.
I tried to change some code I found on here but just not getting me anywhere (code below). I would appreciate any help you might be able to give.
Sub BOM_ColumnCustomizasion_Export ()
Dim oAsmDoc As AssemblyDocument
Set oAsmDoc = ThisApplication.ActiveDocument
Dim oAsmDef As AssemblyComponentDefinition
Set oAsmDef = oAsmDoc.ComponentDefinition
Dim oBOM As BOM
Set oBOM = oAsmDef.BOM
Dim filename As String
filename = "c:\temp\BOM_Columns.xml"
Call oBOM.ExportBOMCustomization(filename)
Beep
End Sub
Sub BOM_ColumnCustomizasion_Import ()
Dim oBOM As BOM
Dim filename As String 'assume the file exists
Call oBOM.ImportBOMCustomization(filename)
Beep
End Sub
thanks
JD
- Mute
- Permalink
- Report
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition Dim oBOM As BOM = oAsmDef.BOM Dim filename As String = "Fullfilename of the xml" Call oBOM.importBOMCustomization(filename)
please feel free to "kudos"
- Mute
- Permalink
- Report
- Mute
- Permalink
- Report
Is there a way to open the BOM on the structure tab when this rule has been run?
- Mute
- Permalink
- Report
The BOM is allways opened at the tab that was activated when closing the BOM editor.
Maybe in the reg editor there is some option to do this?
- Mute
- Permalink
- Report
It doesn’t have to open on that tab. I just want to be able to use the code below and want it to open the BOM to view with the same rule.
SyntaxEditor Code Snippet
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition Dim oBOM As BOM = oAsmDef.BOM Dim filename As String = "P:\Engineering\Inventor\BOM List\Profit Key BOM.xml" Call oBOM.importBOMCustomization(filename)
- Mute
- Permalink
- Report
Then this is what you need
'Open BOM editor dialog box
Dim oCtrlDef As ControlDefinition
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBillOfMaterialsCmd")
oCtrlDef.ExecuteIf you want to print all commandnames, there is a snippet in de vba help that does this, very helpfull and i have this file all the time with me ![]()
Sub PrintCommandNames()
Dim oControlDefs As ControlDefinitions
Set oControlDefs = ThisApplication.CommandManager.ControlDefinitions
Dim oControlDef As ControlDefinition
Open "C:\temp\CommandNames.txt" For Output As #1
Print #1, Tab(10); "Command Name"; Tab(75); "Description"; vbNewLine
For Each oControlDef In oControlDefs
Print #1, oControlDef.InternalName; Tab(55); oControlDef.DescriptionText
Next
Close #1
End Sub
- Mute
- Permalink
- Report
Thank you so much for your help. I’m still having a little trouble. Below is the code I’m using in visual basic for a button command. It is not understanding “Thisapplication” command. Frederic you code worked great when run in a rule. I just can get it to work in the application I’m trying to make. I would appreciate if you could look this code over to see what I’m doing wrong. I know that it’s close.
Thank you
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click If _invApp.Documents.Count = 0 Then MsgBox("Need to open an Assembly document") Return End If If _invApp.ActiveDocument.DocumentType <> _ DocumentTypeEnum.kAssemblyDocumentObject Then MsgBox("Need to have an Assembly document active") Return End If Dim asmDoc As AssemblyDocument asmDoc = _invApp.ActiveDocument Dim oAsmDoc As AssemblyDocument = _invApp.ActiveDocument Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition Dim oBOM As BOM = oAsmDef.BOM Dim filename As String = "P:\Engineering\Inventor\BOM List\Profit Key BOM.xml" Call oBOM.ImportBOMCustomization(filename) 'Open BOM editor dialog box Dim oCtrlDef As ControlDefinition oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBillOfMaterialsCmd") oCtrlDef.Execute() End Sub
- Mute
- Permalink
- Report
Thisapplication works in vba & illogic, just replace it with your _invApp and it will work if you _invApp is properly declared
- Mute
- Permalink
- Report
Thank you. I know it was something simple that I was over looking. Thanks again for your help.
