08-02-2016
09:30 PM
- Mute
- Permalink
- Report
08-02-2016
09:30 PM
Nice manners. They go well with that snarky attitude.
Step 2: "What is a NameValueMap?"
SO.
Something like this will be the name value map. (I'm writing this in vb.net, whereas almost all of the samples use vba, and vb.net is what is used in the rule environment)
oSomeCustomLength = "24 in"
Dim oNVM As NameValueMap
oNVM = ThisApplication.TransientObjects.CreateNameValueMap
oNVM.Value("LengthParamColumnNameFromContentCenterEditor") = oSomeCustomLength
To finish off, insert it back into the CreateFamilyMember line as the optional parameter that it is.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
