OK, new idea.
Use this ilogic code to create a user parameter called mass and fill that parameter with the mass of the part.
SyntaxEditor Code Snippet
Try
    Parameter("Mass")=iProperties.Mass
    Catch
    oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
    oParameter=oMyParameter.AddByExpression("Mass", "5", "kg")
    'oParameter=oMyParameter.AddByValue("Mass", "", UnitsTypeEnum.kKilogramMassUnits)
End Try
Then in document settings change the base quantity to the new parameter and bingo!
You can set the rule to run every time you save so the mass always gets updated
