- Mute
- Permalink
- Report
Hello everyone,
I'm currently working on a rule and I have one slight problem. The problem is that this rule returns the measurements from the assembly, I want the measurements from the referenced documents.
Sub Main()
Dim StartTime As DateTime
Dim aElapsedTime As TimeSpan
StartTime = Now
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
aPropParNum = oAsmDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
aFileNameWithoutExt = IO.Path.GetFileNameWithoutExtension(oAsmDoc.FullDocumentName)
For Each oRefDoc In oRefDocs
bPropParNum = oRefDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
bFileNameWithoutExt = IO.Path.GetFileNameWithoutExtension(oRefDoc.FullDocumentName)
bFullpath = IO.Path.GetFullPath(oRefDoc.FullDocumentName)
bFileName = IO.Path.GetFileName(oRefDoc.FullDocumentName)
If oRefDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
If InStr(bFileNameWithoutExt, "koker", CompareMethod.Text) = 1 Then
ThisApplication.Documents.Open(bFullpath, True)
InventorVb.DocumentUpdate()
aDocument = ThisApplication.ActiveDocument
iProperties.Value(aDocument, "Custom", "aMeasure") = Measure.ExtentsHeight
iProperties.Value(aDocument, "Custom", "bMeasure") = Measure.ExtentsWidth
iProperties.Value(aDocument, "Custom", "cMeasure") = Measure.ExtentsLength
If aDocument.Open Then aDocument.Close(True)
End If
End If
Next
aElapsedTime = Now().Subtract(StartTime)
bElapsedTime = aElapsedTime.TotalSeconds
oWrite = System.IO.File.CreateText("X:\01 productie\25 Werkvoorbereiding\07 Zaaglijsten\" & aFileNameWithoutExt & ".txt")
oWrite.WriteLine(aFileNameWithoutExt & vbCrLf & DateString & " " & Timestring)
oWrite.WriteLine("All data was collected in " & Round(bElapsedTime, 2) & "s" & vbCrLf & "")
oWrite.WriteLine("Tubes:" & vbCrLf & oListB)
oWrite.Close()
End Sub
Thank you, Stan Mertens
- Mute
- Permalink
- Report
Hi Stan,
sorry for the late response....![]()
If you use "aDocument" as reference you will give wrong informations to the application and then you get back wrong results.
You should use "oRefDoc.DisplayName" instead.
********* iProperties.Value(oRefDoc.DisplayName, "Custom", "aMeasure") = Measure.ExtentsHeight iProperties.Value(oRefDoc.DisplayName, "Custom", "bMeasure") = Measure.ExtentsWidth iProperties.Value(oRefDoc.DisplayName, "Custom", "cMeasure") = Measure.ExtentsLength ********
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
- Mute
- Permalink
- Report
Thank you very much. I'm currently at vacation, coming monday i will be back at work. I will give you feedback as soon as i tried your code.
Stan.
- Mute
- Permalink
- Report
Hi Rossano,
I've tried your modifications in the following code:
Sub Main()
StartTime = Now
If InStr(bFileNameWithoutExt, "buis", CompareMethod.Text) = 1 Then
End If
End If
Next
' oWrite = System.IO.File.CreateText("X:\01 productie\25 Werkvoorbereiding\07 Zaaglijsten\" & aFileNameWithoutExt & ".txt")
' oWrite.WriteLine(aFileNameWithoutExt & vbCrLf & DateString & " " & Timestring)
' oWrite.WriteLine("All data was collected in " & Round(bElapsedTime, 2) & "s" & vbCrLf & "")
' oWrite.WriteLine("Tubes:" & vbCrLf & oListB)
' oWrite.Close()
End Sub
It does exactly the same as it did before (see screenshot). The rule returns the measurements from the assembly to the referenced documents, I want the measurements from referenced documents to be returned to the referenced documents themselves.
Stan.
- Mute
- Permalink
- Report
Hi Stan,
the following function calculate all three dimensions of a component definition.
Sub Main()
StartTime = Now
'If InStr(bFileNameWithoutExt, "koker", CompareMethod.Text) = 1 Then
'ThisApplication.Documents.Open(bFullpath, True)
'InventorVb.DocumentUpdate()
iProperties.Value(aDocument, "Custom", "aMeasure") = mSize(oRefDoc,"z")'Measure.ExtentsHeight
iProperties.Value(aDocument, "Custom", "bMeasure") = mSize(oRefDoc,"y")'Measure.ExtentsWidth
iProperties.Value(aDocument, "Custom", "cMeasure") = mSize(oRefDoc,"x")'Measure.ExtentsLength
'If aDocument.Open Then aDocument.Close(True)
'End If
End If
Next
' oWrite.Close()
End Sub
Private Function mSize(oDoc As Inventor.Document, t As String) As String
cD = oDoc.ComponentDefinition
If cD IsNot Nothing Then
Select Case UCase(t)
Case "X" ' X is extent length
X = Math.Abs(cD.RangeBox.MinPoint.X - cD.RangeBox.MaxPoint.X)
mSize = Round(oDoc.UnitsOfMeasure.ConvertUnits(X,"cm" ,oDoc.UnitsOfMeasure.LengthUnits )).ToString
Case "Y" ' Y is extent width
Y = Math.Abs(cD.RangeBox.MinPoint.Y - cD.RangeBox.MaxPoint.Y)
mSize = Round(oDoc.UnitsOfMeasure.ConvertUnits(Y,"cm" ,oDoc.UnitsOfMeasure.LengthUnits )).ToString
Case "Z" ' Z is extent height
Z = Math.Abs(cD.RangeBox.MinPoint.Z - cD.RangeBox.MaxPoint.Z)
mSize = Round(oDoc.UnitsOfMeasure.ConvertUnits(Z,"cm" ,oDoc.UnitsOfMeasure.LengthUnits )).ToString
End Select
End If
End Function
Why you should use this function instead of using the feature "Measure"?
I think it's more versatile because you need only to reference a document....no matter where is it.
Bregs
Rossano Praderi
NB: you have defined two variables that refer to the same document ("aAsm" & "aDocument"), every time you pass throught the loop "for/next" you assign everytime the same variable with the same document (I haven't check everything, but I only seen this as unnecessary).
- Mute
- Permalink
- Report
