855 Views, 4 Replies
Inventor 2016 Parts List Quantity Edit
Good day everyone,
I have been given a task that I am not sure if possible and if it is then I would need some of your expert advice and guidance to get it right.
So here is my scenario:
Let's say I have an Assembly with 10 Parts in, and some of them are the same parts. When you look in the Parts List you will only be shown all the different parts and then given the quantity of each. So let's say there is 5 different parts in total.
It is fine with it displaying like that (Showing the quantities of each part) but, now I have one part of which I want the Mass/Volume of.
Now I know you can add a Mass or Volume Column, but the problem is we only want to see the one Parts Mass and then the others Parts Quantities and we want to be able to see it in one Column
For Example:
ITEM   -   QTY   -   DESCRIPTION
  1       -    1      -    PART 1
  2       -    3      -    PART 2
  3       -    2      -    PART 3
  4       -    3      -    PART 4
  5       -   3kg   -    PART 5
Is something like this at all possible?
Looking forward to seeing the responses and hoping for a good solution to this, thanks
Tags (2)
