07-12-2016
07:14 AM
- Mute
- Permalink
- Report
07-12-2016
07:14 AM
Hi. Trying to learn to fish for a day, I see!
Here's how you learn to fish for a lifetime:
1. Go/Find the file below on your computer.
"C:\Program Files\Autodesk\Inventor 2016\Local Help\admapi_20_0.chm"
2. Open it, to the index tab.
3. Search for "Content Center"
4. Navigate through the tree until you find your answer.
I found it in all of 10 seconds.
Good luck!
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
