400 Views, 2 Replies
07-12-2016
06:27 AM
- Mute
- Permalink
- Report
07-12-2016
06:27 AM
Hi All,
i am writing a rule wich accsesses the parameters of the holefeatures in my parts.
When i use the code below on a part with a counterbore hole it only returns the parameter of the drilled part and ingnores the
depth and the diameter of the counterbore.
I attached the partfile with the rule.
SyntaxEditor Code Snippet
Dim oDoc as Inventor.PartDocument = ThisDoc.Document Dim oParam as Inventor.Parameter Dim oTol as Inventor.Tolerance Dim i As Integer Dim oFeat As PartFeature Dim oDim as FeatureDimension For i=1 To oDoc.ComponentDefinition.Features.count oFeat=oDoc.componentdefinition.Features.item(i) If oFeat.Type = 83912192 Then '83912192 = Holefeatures For n=1 To oFeat.FeatureDimensions.count oDim=oFeat.FeatureDimensions.item(n) oParam = oDim.Parameter MessageBox.Show(oFeat.Type & oParam.Name & oParam.Tolerance.HoleTolerance, " ", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) Next End If Next
