1971 Views, 11 Replies
Inventor C# Listener
I am using Inventor api with C#. I want create a listener for Inventor 2016. For example Let alert (message.box) when opened save as dailog or etc.
Jef_E
Sounds cool and what is the question here?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
in reply to: Jef_E
I said. How can I listen Inventor API with C# ? Can you give me sample codes or tricks.
Jef_E
Hmm does not seem like you said that..
I want to..
How to..
what version of Inventor are you using? there are enough sample in the API to do this I think. I don't have C# code to show for.. only VB.NET if you can translate it?
Inventor 2014 SP2
tolgay.hickiran
in reply to: Jef_E
I'd love to see that Jef
Some worthwhile ideas
Copy Design should rename ilogic Rules too!
Why Nastran In-CAD doesn't have an SDK?IMPLEMENTED!
Tolgay Hickiran
Founding Partner
SignatureSignature
website
emailskypelinkedinyoutubeemail
nmunro
in reply to: tolgay.hickiran
Inventor ships with an event watcher tool. Install the developer tools and look for EventWatcher.exe
https://c3mcad.com
in reply to: Jef_E
I am using Inventor 2016 Premium. Yes Jef_E, I can translate vb to c#. If you give me any sample I be to happy.
Jef_E
As stated by @nmunro
I attached a zip file with the event watcher from Autodesk written in vb.net
Inventor 2014 SP2
in reply to: Jef_E
Can you compile your sended project ? I see that in developer tools but was giving compile error as your sended.
Jef_E
Change the target framework..
Inventor 2014 SP2
İrfan Şahin dostum;
Did you translate Mr. Jef's VB codes to C#?
I just need handling of OnDocumentActive, but not as addin; I'm trying to make an executable application. May you help me?
Thanks in advance to everybody.
using System;
using Inventor;
namespace WpfInventor45
    public interface IApplicationEventsLib
        ApplicationEvents ApplicationEvents { get; }
        ApplicationEventsSink_OnActivateDocumentEventHandler OnActivateDocumentDelegate
            get;
            set;
        void Deactivate();
        void I_Need_This(Inventor._Document DocumentObject, Inventor.EventTimingEnum BeforeOrAfter, Inventor.NameValueMap Context, ref Inventor.HandlingCodeEnum HandlingCode);
    public class ApplicationEventsLib : IApplicationEventsLib
        private readonly Application inventorApp;
        public ApplicationEventsLib(Application inventorApp)
            this.inventorApp = inventorApp;
            ApplicationEvents = this.inventorApp.ApplicationEvents;
            Activate();
        public ApplicationEventsSink_OnActivateDocumentEventHandler OnActivateDocumentDelegate
            get; set;
        public ApplicationEvents ApplicationEvents { get; private set; }
        public void I_Need_This(Inventor._Document DocumentObject, Inventor.EventTimingEnum BeforeOrAfter, Inventor.NameValueMap Context, ref Inventor.HandlingCodeEnum HandlingCode)
            if ((BeforeOrAfter == Inventor.EventTimingEnum.kAfter))
                Console.WriteLine("Code here!!");
        private void Activate()
// I'm Getting error: No overload for .. matches delegate.. OnActivateDocumentDelegate = new ApplicationEventsSink_OnActivateDocumentEventHandler(I_Need_This);
ApplicationEvents.OnActivateDocument += OnActivateDocumentDelegate; } public void Deactivate() { ApplicationEvents.OnActivateDocument -= OnActivateDocumentDelegate; OnActivateDocumentDelegate = null; } } }
In VB using ByRef works, but in C# it does not!
I found the solution: out in, ref out  Smiley Happy
For the ones like me in yesterday..
using Inventor; //autodesk.inventor.interop
private Inventor.Application m_App = null;
private Inventor.ApplicationEvents m_ApplicationEvents = null;
private void Window_Loaded(object sender, RoutedEventArgs e)
            try
//Inventor.Application application = (Inventor.Application)System.Runtime.InteropServices.Marshal.GetActiveObject("Inventor.Application"); m_App = InitializeInventor(true, true); if (m_App != null) { m_ApplicationEvents = m_App.ApplicationEvents; m_App.ApplicationEvents.OnActivateDocument += ApplicationEvents_OnActivateDocument; m_App.ApplicationEvents.OnQuit += ApplicationEvents_OnQuit; } else System.Environment.Exit(0); } catch { } } void ApplicationEvents_OnQuit(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode) { switch (BeforeOrAfter) { case EventTimingEnum.kBefore: //Do Something; HandlingCode = HandlingCodeEnum.kEventNotHandled; break; default: HandlingCode = HandlingCodeEnum.kEventNotHandled; break; } } //Use out instead of ref void ApplicationEvents_OnActivateDocument(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode) { HandlingCode = HandlingCodeEnum.kEventNotHandled; //This line is Important if ((BeforeOrAfter == Inventor.EventTimingEnum.kBefore)) { //Do Something } }
Tags:
"Inventor Application Events"
"Handling Inventor Events Using C#"
"Inventor OnActvateDocument"
"ApplicationEventsSink_OnActivateDocumentEventHandler"
