Jef_E
This should be run as VBA macro but it can work as iLogic code too.
Some simple adjustments should do.
I corrected the error as the message stated in your reply
Error in rule program format:
All other Sub's or Function's must be after Sub Main()
And commented the debug messages because iLogic cant debug.. sadly.. :slightly_smiling_face:
You now have to choose what you want to do with it and tell it to do so. Because this does not do anything at the moment. If you want to export values into excel you should teach it how to do so.
Sub  Main BOMQuery()
    ' a reference to the assembly document.
    ' This assumes an assembly document is active.
    Dim oDoc As AssemblyDocument
    oDoc = ThisApplication.ActiveDocument
    Dim FirstLevelOnly As Boolean
    If MsgBox("First level only?", vbYesNo) = vbYes Then
        FirstLevelOnly = True
    Else
        FirstLevelOnly = False
    End If
    ' a reference to the BOM
    Dim oBOM As BOM
    oBOM = oDoc.ComponentDefinition.BOM
    ' whether first level only or all levels.
    If FirstLevelOnly Then
        oBOM.StructuredViewFirstLevelOnly = True
    Else
        oBOM.StructuredViewFirstLevelOnly = False
    End If
    ' Make sure that the structured view is enabled.
    oBOM.StructuredViewEnabled = True
    'a reference to the "Structured" BOMView
    Dim oBOMView As BOMView
    oBOMView = oBOM.BOMViews.Item("Structured")
    'Debug.Print "Item"; Tab(15); "Quantity"; Tab(30); "Part Number"; Tab(70); "Description"
    'Debug.Print "----------------------------------------------------------------------------------"
    'Initialize the tab for ItemNumber
    Dim ItemTab As Long
    ItemTab = -3
    Call QueryBOMRowProperties(oBOMView.BOMRows, ItemTab)
End Sub
Private Sub QueryBOMRowProperties(oBOMRows As BOMRowsEnumerator, ItemTab As Long)
    ItemTab = ItemTab + 3
    ' Iterate through the contents of the BOM Rows.
    Dim i As Long
    For i = 1 To oBOMRows.Count
        ' Get the current row.
        Dim oRow As BOMRow
        oRow = oBOMRows.Item(i)
        'a reference to the primary ComponentDefinition of the row
        Dim oCompDef As ComponentDefinition
        oCompDef = oRow.ComponentDefinitions.Item(1)
        Dim oPartNumProperty As Inventor.Property
        Dim oDescripProperty As Inventor.Property
        If TypeOf oCompDef Is VirtualComponentDefinition Then
            'Get the file property that contains the "Part Number"
            'The file property is obtained from the virtual component definition
            oPartNumProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Part Number")
            'Get the file property that contains the "Description"
            oDescripProperty = oCompDef.PropertySets _
                .Item("Design Tracking Properties").Item("Description")
            'Debug.Print Tab(ItemTab); oRow.ItemNumber; Tab(17); oRow.ItemQuantity; Tab(30); _
            '    oPartNumProperty.Value; Tab(70); oDescripProperty.Value
        Else
            'The file property is obtained from the parent
            'document of the associated ComponentDefinition.
            oPartNumProperty = oCompDef.Document.PropertySets _
            oDescripProperty = oCompDef.Document.PropertySets _
            'Recursively iterate child rows if present.
            If Not oRow.ChildRows Is Nothing Then
                Call QueryBOMRowProperties(oRow.ChildRows, ItemTab)
            End If
        End If
    Next
    ItemTab = ItemTab - 3
End Sub
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
