567 Views, 4 Replies
Change ReadOnly in Form with iLogic
     I have a bunch of components that have forms in them. Not global forms, but forms in the document. I would like to replace these forms via ilogic with a new version. The intent is to iterate over the documents and subdocuments and check the value of an iproperty. if iprop value = x then delete embedded form/s, and copy new from this template... We have a system of components driven by forms, for example, a glass part contains a form called "glass definition" that is supposed to interact with the part ion specific ways. as this part gets copied and made into new versions, the forms get "tweaked" over time. This is BAD.... I need to be able to go into an assembly and reform (pun intended) the "tweaked" forms back to a consistent interface. I cant open every part and delete, copy, & paste. I only have a couple of thousand suspect parts... Thanks in advance for whatever help you can Provide!
Tom Ruscher
