AccessibleObjectFromWindow out of scope means?
The developers didn't create in the Inventor API com component the logic required to make this work at all?
OR
The API help team doesn't support with this level of coding (com level that requires dll imports) because they are not paid to do so?
In short am I wasting my time attempting to convert this specific window handle (IntPtr) into the app object, because I am so close to solving this?
268620	  Afx:00007FF789EB0000:8:0000000000010005:0000000000000000:0000000000080CE7
268620	Inventor.Application.MainFrameHWND
  Private Declare Function AccessibleObjectFromWindow Lib "oleacc" (ByVal Hwnd As Int32, ByVal dwId As Int32, ByRef riid As Guid, <MarshalAs(UnmanagedType.IUnknown)> ByRef ppvObject As Object) As Int32
    Dim FoundWindows As List(Of IntPtr)
    Private Declare Function GetDesktopWindow Lib "user32" () As Integer
    Private Declare Function EnumChildWindows Lib "user32.dll" (ByVal WindowHandle As IntPtr, ByVal Callback As EnumWindowsProc, ByVal lParam As IntPtr) As Boolean
    Private Declare Function GetWindowText Lib "user32.dll" Alias "GetWindowTextA" (ByVal hwnd As IntPtr, ByVal lpString As String, ByVal cch As Int32) As Int32
    Private Declare Function GetClassName Lib "user32.dll" Alias "GetClassNameA" (ByVal hWnd As IntPtr, ByVal lpClassName As String, ByVal nMaxCount As Integer) As Integer
    Private Declare Function GetWindowTextLength Lib "user32.dll" Alias "GetWindowTextLengthA" (ByVal hwnd As IntPtr) As Int32
    Private Delegate Function EnumWindowsProc(ByVal hwnd As IntPtr, ByVal lParam As Int32) As Boolean
    Private Const OBJID_NATIVEOM = &HFFFFFFF0
    Private Const OBJID_CLIENT = &HFFFFFFFC
Private Sub ListDebug()
        'calling code
        FoundWindows = New List(Of IntPtr)
        Dim WindowHandle As IntPtr = GetDesktopWindow()
        EnumChildWindows(WindowHandle, AddressOf ListInventorChildWindows, 0)
        Dim guid As New Guid("{B6B5DC40-96E3-11d2-B774-0060B0F159EF}")
        Dim InventorApplication As Inventor.Application
        Dim InvObject As Object = Nothing
        For i As Integer = 0 To FoundWindows.Count - 1
            AccessibleObjectFromWindow(FoundWindows(i), OBJID_CLIENT, guid, InvObject)
            If Not InvObject Is Nothing Then
                InventorApplication = InvObject.Application
            End If
        Next
    End Sub
    Public Function ListInventorChildWindows(ByVal hwnd As IntPtr, ByVal lParam As Int32) As Boolean
        Dim WindowTitle As String, Ret As Integer
        Dim ClassName As String
        ClassName = Space(255)
        Ret = GetClassName(hwnd, ClassName, 255)
        ClassName = ClassName.Substring(0, Ret)
        Debug.Print("[" & hwnd.ToString & "]  " & ClassName)
        If ClassName.Contains("Afx:00007FF789EB0000:8:0000000000010005:0000000000000000:") Then
            Ret = GetWindowTextLength(hwnd)
            WindowTitle = Space(Ret)
            GetWindowText(hwnd, WindowTitle, Ret + 1)
            Debug.Print("Window Text: " & WindowTitle)
            FoundWindows.Add(hwnd)
        End If
        Return True
    End Function
jvj
