487 Views, 0 Replies
Supress Part at Subassembly by Ilogic Rule
Hello Community,
i got following problems with Inventor 2014 and Ilogic.
I try to suppress parts in a Subassembly by using a Ilogic rule.
The Rule i create at Main Assembly and a User Level of Detail because At Master i can`t suppress Parts at Assembly.
My Ilogic Rule is
If iProperties.Value("Custom", "Varia")= True Then
Component.IsActive("Tank2") = True
Component.IsActive(MakePath("Subassembly1:1", "Part1:1")) = True
Else If iProperties.Value("Custom", "Varia")= False Then
Component.IsActive("Tank2") = False
Component.IsActive(MakePath("Subassembly1:1", "Part1:1")) = False
End If
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 11936 StartFragment: 314 EndFragment: 11904 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
My Problem is that Tank 2 will suppressed if the condition is fulfilled but  Part1:1 at Subassembly1:1 are unsuppressed.
The condition can changed over an IPropertie "Varia" as Boolean that i create at Main assembly.
I have at the moment no Idea to solve that problem.
What i also try was to create a Rule in Subassembly who is influente by a Parameter at Subassembly.
But i can`t link String or Boolean Parameters to the Main Assembly Parameter list. It only works for Numeric Parameters.
And if i use Numeric Parameter at Subassembly and link to Main Assembly i can´t change the Value of the Parameter at Main Assembly cause the Value is write protected.
The Way from Main Assembly to Subassembly doesnt work because Inventor says it will create a cyclic dependency.
Why i try to use Ilogic is??
I got a Main Assembly with 2050 Parts and i want to create different Variants of this Assembly. Sometimes i have to Replace Parts and Sometimes i have to activate or deactivate Components.
I want to controll over an Ilogic form the variation of the Main Assembly.
IAssembly is no solution for me because i can only suppress complete Subassemblys over IAssembly and not some Parts in Subassembly.
I anyone have an Idea feel free to responds.
And if Anyone knows a source of an Ilogic Documentation additional to the Autodesk Help also responds
With Regards
Gandalf
