in reply to:
06:07 AM
- Mute
- Permalink
- Report
07-05-2016
06:07 AM
The iLogic code seems to work w/o issues.
http://adndevblog.typepad.com/manufacturing/2013/07/inventor-2014-api-set-part-material.html
Sub Main()
Dim i As Integer
Dim oApp As Inventor.Application
oApp = ThisApplication
If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Active document is NOT an assembly document!","DEBUG ME")
Exit Sub
End If
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim strMaterialNameToChange As String
strMaterialNameToChange = "Aluminum 6061"
Dim strNewMaterialName As String
strNewMaterialName = "Steel, Galvanized" '"Aluminum 6061"
Dim oMat As Asset
' MessageBox.Show("ASSEMBLY DOCUMENT!","iLogic Debug")
Dim oOcc As ComponentOccurrence
Dim oPartDoc As PartDocument
Dim newMat As Asset
For Each oOcc In oDoc.ComponentDefinition.Occurrences.AllLeafOccurrences
oPartDoc = oOcc.Definition.Document
For i = 1 To oPartDoc.Assets.Count
If oPartDoc.Assets.Item(i).DisplayName = strNewMaterialName Then
oMat = oPartDoc.Assets.Item(i)
bMatFound = True
' MessageBox.Show("MATERIAL FOUND!","iLogic Debug")
Exit For
End If
Next i
If oPartDoc.ActiveMaterial.DisplayName = strMaterialNameToChange And oOcc.Definition.IsContentMember = False Then
' MessageBox.Show("IN if/then","iLogic Debug")
oPartDoc.ActiveMaterial = oMat
End If
Next
Call oDoc.BrowserPanes.ActivePane.TopNode.DoSelect
End Sub
