360 Views, 1 Reply
06-30-2016
02:46 AM
- Mute
- Permalink
- Report
06-30-2016
02:46 AM
I'm trying to pattern a component using another components axis in an assembly:
Public Sub Pattern()
Dim oADoc As AssemblyDocument = InvApp.ActiveEditDocument
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim InvPart1 As ComponentOccurrence = oADef.Occurrences.Item(1)
Dim InvPart2 As ComponentOccurrence = oADef.Occurrences.Item(2)
Dim oAxis As WorkAxis = InvPart1.Definition.workaxes(1)
MsgBox("Part1 : " & InvPart1.Name & vbCr & "Part2 : " & InvPart2.Name & vbCr & "Axis : " & oAxis.Name)
Dim oOccPatterns As OccurrencePatterns = oADef.OccurrencePatterns
Call oOccPatterns.AddCircularPattern(InvPart2, oAxis, True, "45 deg", 8)
End Sub
The message box proves that it is successfully finding the two compoents and the X Axis of the first component.
It keeps falling over on the last line, when trying to create the pattern, I've tried creating a workaxisproxy but found this made no difference.
attached is the assembly file I've been trying it out on
Any help with this would be great.
