361 Views, 1 Reply
Create Circular Pattern in assembly
I'm trying to pattern a component using another components axis in an assembly:
    Public Sub Pattern()
        Dim oADoc As AssemblyDocument = InvApp.ActiveEditDocument
        Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
        Dim InvPart1 As ComponentOccurrence = oADef.Occurrences.Item(1)
        Dim InvPart2 As ComponentOccurrence = oADef.Occurrences.Item(2)
        Dim oAxis As WorkAxis = InvPart1.Definition.workaxes(1)
        MsgBox("Part1 : " & InvPart1.Name & vbCr & "Part2 : " & InvPart2.Name & vbCr & "Axis : " & oAxis.Name)
        Dim oOccPatterns As OccurrencePatterns = oADef.OccurrencePatterns
        Call oOccPatterns.AddCircularPattern(InvPart2, oAxis, True, "45 deg", 8)
    End Sub
The message box proves that it is successfully finding the two compoents and the X Axis of the first component.
It keeps falling over on the last line, when trying to create the pattern, I've tried creating a workaxisproxy but found this made no difference.
attached is the assembly file I've been trying it out on
Any help with this would be great.
For everyone's info,
I've got this workaround:
        Dim Invpart1Def As PartComponentDefinition = InvPart1.Definition
        Dim oObjects As ObjectCollection
        Dim oFeature As CircularPatternFeature
        Dim oFeatureProxy As CircularPatternFeatureProxy
        oObjects = InvApp.TransientObjects.CreateObjectCollection
        oObjects.Add(InvPart2)
        oFeature = Invpart1Def.Features.CircularPatternFeatures.Item(1)
        Call InvPart1.CreateGeometryProxy(oFeature, oFeatureProxy)
        Call oADef.OccurrencePatterns.AddFeatureBasedPattern(oObjects, oFeatureProxy)
    End Sub
This works with the assembly I posted, as long as the first item has a circular pattern to use.
