The code below seems to work fine with an assembly file.
Sub Main()
Dim oApp As Inventor.Application
oApp = ThisApplication
If ThisApplication.ActiveDocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("ERROR - Active Document is not an assembly document!","iLogic Error")
	Exit Sub
End If
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
MessageBox.Show("ASSEMBLY DOCUMENT!","iLogic Debug")
Dim strMaterialNameToChange As String
strMaterialNameToChange = "Aluminium"
Dim strNewMaterialName As String
strNewMaterialName = "Steel"
Dim oOcc As ComponentOccurrence
For Each oOcc In oDoc.ComponentDefinition.Occurrences.AllLeafOccurrences
   If oOcc.Definition.Material.Name = strMaterialNameToChange And oOcc.Definition.IsContentMember = False Then
         oOcc.Definition.Material = oDoc.Materials.Item(strNewMaterialName)
   End If
Next
End Sub
