DP-Mike
758 Views, 0 Replies
SX-Frac.shx font ascii code
I have an old drawing from 1997 I am using for information. The drawing uses the font SX-FRAC.shx. I am trying to figure out the ascii codes and symbols
I know this font was changed to Romans.shx after 1998. (I think in Cad Version 14.) so I don't expect anyone to actually have a copy of it. But if you did, that would be awesome.
I've tried substituting Romans.shx inplace of sx-frac, but it does not work. All of the fraction in the drawing that were using the ascii code, example; %%202 = 1/8" fraction, are still showing up as other symbols. Example; capital E with lines above, or two dots. Capital I with stuff above. Capital N with a squigly above it.
Through a work around (essentially creating a text string for characters 201 to 233) I have created a cheat sheet for the symbols. However; %%208 and %%222 did not show up correctly. I am pretty sure 208 is 1/2". and I think 222 is 11/32" But I am not sure..
There are also symbols in the original drawings that did not appear in my cheat sheet.  One specific symbol is a capital "D" with a hash in the center of the vertical part of the D.
I need to know what these symbols are in Ascii so I can figure out what they are SUPPOSED to be in the old version of the drawing.
Thanks for any help.
Mike
