Winks87
363 Views, 1 Reply
Data Std File Name sequence...
Ok, not a big issue but, a little confusing.  When creating a new part within an assembly, I get the filename box generated by data standard, ONLY the file name box.  I usually select skip until I hit save then I get the full file name, Title, Description, folder location input box...is this standard behavior?  Is this because I am trying to create files within the assembly?   I know, I should be creating a new part outside of assembly, but sometimes it's easier to do it inside assembly.  Is this normal behavior for this workflow?  Thoughts?
James Winkler
