411 Views, 1 Reply
Change Rep View of sub-assembly Pattern
Hello Community,
I need some Help...:)
I have an assembly (Lage_D) with a pattern of a subassembly (Teileraum) in it.
The pattern is created by a rule in the main assembly, the quanity of the pattern-objects is driven by the size of the subassembly.
If i manualy set the View rep to my specivic view, and the quantity of the pattern changes, the view rep of the new inserted subassemblys won t change!
Like to change the View Rep of each subassembly, in the pattern, by ilogic rule from the main assembly.
Found a lot of code dealing with this, but nothing fitts to my problem.(eg. "change viewrep in part ect." )
Tryed to change the code, but this dosent work properbly, my skills are to poor for this.
Pleas see the attached picture for more information
Thanks for help, will give kudos for every help!
Simon
